Got my 725 this morning (thanks Chris Jnr at CWC!!!)
How do I go about setting the altitude?
Is their a website I can go to, to get some altitude readings of different locations?
Where abouts in Jbg Gauteng are you? I have a GIS system at work that has contour data available for most of the country.
Is their a website I can go to' date=' to get some altitude readings of different locations?
Can't help on what the altitude is, but to set the altitude on the watch...
Options --> Start --> Function Set --> Altitude On --> OK --> and then key in the altitude figure --> OK ---- DONE !
Thanks Buff - do what level can it give data?
Can it give for Gold reef city, Parkhurst, Sunninghill?
I know how to set it, just want to make sure its accurate.
I know how to set it' date=' just want to make sure its accurate.
The only way to set it will be at a Trig Beacon or with the help of a GPS, however the Polar uses barometric pressure to detemine the altitude, which 75% of the time will always be inaccurate given the hourly changes in temperature & pressure.
Eish, I'm not from your neck of the woods so it makes it hard to find specific areas. The contour intervals are 20m so it's very easy to get this wrong without knowing your co-ordinates but you can work with these:
Kempton Park = 1600m
Sandton = 1540m
Fourways = 1460m
Jason - At the main set of robots at Grand Central the height is 1600m.
At the entrance to Kyalami it's 1440m.
Comparing to Google Earth - Grand central robots are at 1597m and Kyalami (I assume you mean the race track) is 1463m
Wondu - is that near Crown mines? If so' date=' the heigh is 1710m.[/quote']
Yip, its pretty close to crown mines, and G.E puts it at 1711m  - pretty good, I'd say.
