i phone heart rate and cadence application
Anybody tried the wahoo heart rate and cadence sensors which are compatible with your i phone ?
Also - is the phone bracket water resistent ?
thanks !
I've got the heart rate thingy ... and it works great. Using it with Endomondo & Garmin heart rate strap.
No idea about the cadence, but based on the heart rate (matched my Garmin ...) it should be good.
Water resistant ... I use a water tight pouch ... mate has the entire wahoo setup ... but its way too big & I just dont like it.
So you have garmin heart rate sensor and you are using it with your phone?
How?
I know the Sony Ericsson Active is Ant+ compatible so it can work with the garmin or any Ant+ device which the Garmin's normally are. I also know there are some heart rate straps that's bluetooth compatible. Are the Iphone's equipped with Ant + ?, I doubt it very much.
Quoted from the Wahoo site
"How it Works
As a member of ANT+ alliance, Wahoo Fitness has created a plug in sensor which interfaceshomeicon1.jpg your iPhone with ANT+ fitness devices."
Fitness Sensors
Wahoo Fitness works with many ANT+ heart rate, foot pod and bicycle speed/cadence sensors. "
And that's how the Iphone interface's with other Ant+ devices.
  • 1 year later...
