Hi All
I am not only new to the forum but also new to the sport. Before I step on any toes, is there a place where I should introduce myself before posting? If not, here goes:
I have accepted a challenge from some mates to enter the W2W in November. Now, I need a bike, fitness, motivation and any tips that I can get. I guess the right place to start would be a bike? I am male, 1.86 m, weighs 98kg. Any suggestions of what I should be getting - please note that I want to spend as little as possible!
Thanks in advance.
Link to comment
https://forum.bikehub.co.za/topic/115104-where-do-i-start/
Share on other sites
  • Replies 150
Good luck. I am also doing it so might see you there. You can get a 29'r hardtail for cheap these days. Try Trail and Tar by Tokai. They are super helpful. Or Lance at Epic bike shop. They are both top bike shops and will help you spend your "little as possible"
Thanks Top Fuel - will check them out! Is that what I need: 29'r hardtail?
Edited by Shotgun
Link to comment
https://forum.bikehub.co.za/topic/115104-where-do-i-start/#findComment-1629279
how much is that?
You will need:
1. Bike - I have a bike that I got for free from Game when I bought a toaster. Not sure it is sufficient.
2. Helmet & Gloves - check
3. Bib - not even sure what this is..? Colourful shirt?
4. Water bottle - check
5. Pump & Maintenance Acc.- semi-check. Not sure what the maintenance entail..
6. Perseverance & the right attitude - check
Link to comment
https://forum.bikehub.co.za/topic/115104-where-do-i-start/#findComment-1629283
Hi All
Thanks in advance.
Look for a decent second hand machine for around 6k,
1k for bibs,
R500 for helmet like bell solar
R350 for gloves, giro all the way
R500 for a camelback. 2L
R750 for shoes with cleats.
The other k for a decent multitool and a cheapish cycle comp.
And you should be good to go.
Link to comment
https://forum.bikehub.co.za/topic/115104-where-do-i-start/#findComment-1629292
how much is that?
You will need:
Sounds like you're good to go. The bib is for when you need to blow your nose. Use it like a permanently attached hanky.
Link to comment
https://forum.bikehub.co.za/topic/115104-where-do-i-start/#findComment-1629295
1k for bibs,
Now that is helpful - thanks alot! Do you agree with the 29'r hardtail? Any particular brand I should be favouring/avoiding?
Link to comment
https://forum.bikehub.co.za/topic/115104-where-do-i-start/#findComment-1629298
