So I had a slight spill yesterday and cracked the calliper and bent the brake disk. The Brakes are Shimano cable disks and its on a cheapo Giant Thermo 1 (Which has served me well) What is the cheapest fix for this? Should I order a new caliper and disk? Should I get the disk straightened (Not likely viable) Should I repair the calliper or just look out for some Hydraulics?
Now the only problem I can see with changing to hydro is the fact that I have dual levers (Deore I think??) that means I will have to swop out the gear and brake levers for separate units…….
Now I know I will get responses like save and upgrade the bike and better components, that is in the pipeline not right now. So all I want to do is get this sorted in the most reliable way possible.
Any suggestions? Any and all welcome
TIA
The cheapest way would be to replace your damaged parts, I suggest you put a add in under the"wanted" items as there are guys and girls again that is removing perfectly servicable parts because there arse is itching to"upgrade"to a higher end component,that way you should be able to get yours replace for much less than buying new or changing the whole gear,brake unit. Good luck.
