Ok, so my Polar s720i seems to be having problems with the initial pickup of my HR. Never used to have a problem.
My routine is still the same, wet the contacts on the strap before I put it on. Only now it either doesn't pickup at 1st, or seems a bit erratic.
I don't think it's the watch as all the bike functions work 100%.
I assume it means I need to replace the battery on the strap?
Your Polar heart rate monitor is a high-tech instrument of
superior design and workmanship and should be treated with
care. The suggestions below will help you fulfill the guarantee
obligations and enjoy this product for many years to come.
Taking care of your Polar heart rate monitor
Store your Polar heart rate monitor and transmitter in a cool and dry
place. Do not store it in any kind of non-breathing material, such as a
plastic bag or a sports bag if it is wet. Sweat and moisture can keep the
transmitters electrodes wet and the transmitter activated, which shortens
the battery life.
Keep your Polar heart rate monitor and transmitter out of extreme cold
(below -10
?C / 14 ?F) and heat (above +50 ?C / 122 ?F).
Do not expose the Polar heart rate monitor and transmitter to direct
sunlight for extended periods, such as by leaving it in a car.
Clean the connector regularly after use with a mild soap and water solution.
Never use alcohol or any abrasive material such as steel wool or cleaning
chemicals on any part of the transmitter.
Do not dry the connector in any other way than with a towel. Rough
handling may damage it.
Never put the connector in a washing machine or a drier!
You can wash the strap in a washing machine at +40? C / 104? F. We
recommend that you use a washing pouch.
We recommend that you wash the strap after each time you have used
it in pool water with a high chlorine content.
Do not spin-dry the strap!
Do not put the strap in a dryer!
Do not iron the strap!
Keep the air pressure channels (three openings on the wrist unit backcover)
clean to make sure that the altitude and temperature measurements
work. Do not insert any objects into the openings.
Do not immerse the speed sensor in water.
Avoid hard hits to the speed sensor as these may cause damage.
Batteries
Transmitter
The estimated average battery life span of the transmitter is 1 year
(2h/ day, 7 days/ week). If your transmitter stops working, it might be
due to the battery running out. We recommend that you have the
battery replaced by an authorized Polar Service Center only.
You can, however, change the battery yourself by following the
instructions below. To change the battery, you need a coin, a sealing
ring and a battery (CR2025).
1. Open the connector's battery cover by turning it counterclockwise with
the coin from the CLOSE position to the OPEN position. The cover pops
out from its niche.
2. Remove the battery cover from the connector, lift the battery from the
niche and replace it with a new battery.
3. Remove the sealing ring of the battery cover and replace it with a new
ring.
4. Place the negative (-) side of the battery against the connector and the
positive (+) side against the cover.
5. Put the battery in the connector's niche and put the cover on so that the
arrow points to the OPEN position. Make sure that the cover's sealing
ring is placed correctly in its groove.
6. Gently press the cover deep enough so that its exterior surface is on the
same level as the connector's surface.
7. Turn the cover clockwise so that the arrow on the cover turns from OPEN
to CLOSE. Make sure that the cover is closed properly!
In order to ensure the maximum life span of the connector
?s battery
cover, open it only when you need to change the battery. We
recommend that you change the sealing ring of the battery cover every
time you change the battery. You can get the sealing ring/battery kits
from well-equipped Polar retailers and authorized Polar Services. In the
USA and Canada: Additional sealing rings are available from an
Have a problem.  Did all I had to do, but I think that I got a dud battery.
And don't take it to hot spot in pretoria.  They can't replace.
..................... and dont take it to Bruce in Lynnwood road, they will try to do it and in the process stuff up the seals!!!!!
Oom H klink maar of die die beste is om hom na Polar se shoppie te neem om seker te maak hy word nie gestuff nie.  Is nie lekker om die hele tyd te sukkel met die polar goedjies nie.
Onthou my een monitor Cardiosport was seker nog die beste een wat ek gehad het tot my pa hom gestuff het, en dan ook my Polar H4 wat ook 'n lekker watchie was.  Ai die goeie ou dae
..................... and dont take it to Bruce in Lynnwood road' date=' they will try to do it and in the process stuff up the seals!!!!![/quote']
Yep, just do it your self - not that difficult
Done it on both of mine without a hassle
Ok, cool, thanks for all the suggestions.
I'll replace the battery, any idea where I can get a new seal (in CT)?
They will not keep spares like this. Seal fat may help!!!!!!!!
Sooisy daar is nie baie Polar Shops in Lagos nie..... amper soos kaalvoet oor die Drakensberge hier in Nigeria!!!!!!!!
If it's the strap no prob
I open the strap with a R2 coin, spend R4.95 on a new battery at the local Spar
Replace battery and close up with the original R2 coin
Voila!
Works like a charm
wolverine2008-01-08 05:23:24
