It would appear as if the o ring on my lid is not sealing properly. Any idea if this part is replaceable? If so from where? Don't want to buy a new bladder if I do not have to.
Take a sample to an Engineering supply shop and ask them for a food grade replacement O-ring. If they don't have, ask them where you can get one from. (Not the black one) Food grade should be white/"clear" from experience. Otherwise your LBS shop should be able to source one if you don't want the hassle...
Thanks , whats the difference between food grade and normal.
Normal O-rings are manufactured from a material which is not suitable for use in a food environment. They are resistant to heat, solvents etc. Food grade O-rings are designed to be in contact with food products without contaminating/tainting them. They are non toxic as well. Silicone for example is inert (?) and won't taint the product or contaminate it which is what the Camelbak o-rings are made of as far as I know and can see...
Thanks for all the advice. I have contacted an engineering supply shop,I will visit them tomorrow.
