So if i understand you layer the rim with tape, poke a hole where the valve goes and glue valve on, fit tyre leaving a small opening, fill with solution, fit tyre on and inlflate ASAP, spin round so solution can seal.
And if you have problems getting the tyre bead to seat the first time.... try add a second or 3rd layer of tape...
Oh and dont pump it higher than about 40 psi
Made the move over to Tubeless. Geax Saguaro tires. Raced out in Paarl over the weekend and absolutely loved the tires. So glad I made the shift over to tubeless. :clap:
