I have two questions
I took of my wheel and the brake pushed close so the brakepads were to close to get the wheel in .I seperated it with soemthing flat just a little but they are not as open as they were inititaly can I just open them more ?
I also accidiently opened the bleeding screw at the brake itself and a little fluid came out so now when I pull the lever it only cathces at the bottom when I apply the brakes.
Will I have to bleed the system or add fluid to correct it?
