2 x 10 speed chains - what chain link can I use?
I have previously used the older golden 9 speed SRAM Powerlink on my 10 speed MTB system with no problems at all.
Is this right? A friends new 10 speed chain broke on a ride and I (not knowing any better at that stage as my bike was a 9 speed) only had a 9 speed SRAM link, it did not appear to fit, so an amusing 20 minutes was spent trying to get the pin back in after removing the damaged linked.
Previously??
So, what do you use now??
I used it on my previous chain. When I replaced that chain I used the supplied Shimano pin and, touch wood, have not had to mend any broken chains along the trails as yet. ( @theuniverse: Please note that this post is not intended to tempt fate)
A 9-speed link is identical to a 10-speed link in all ways other than it's width. A 9-speed link is slightly wider and will thus very easily fit onto a 10-speed chain, albeit a bit loose.
Two problems could occur:
It will make a clicking noise at it goes through the rear sprockets. The 9-speed link will touch an adjacent sprocket and cause a click or even a slight skip.
It can come off by itself. Since a chain link requires two movements to disengage - compressing and diagonal sliding, a loose link could compress when shifting gears and whilst straddling two sprockets, even slide open.
If I'm in an 10-speed emergency and someone offers me a 9-speed link, I'll take it but replace it once back home.
There is a way to remove it and once you got the hang of it , its very easy . It involves a long nose plier , bend the chain 90d at the link and use plier on outside of chain !!! w00t.gif
clever you are...the force has taught you well
