Building First Single Speed - need Help plus other plans
Okay so I am starting with a road single speed as i have all the bits and a spare roadbike frame. Frame is an old Trek 5500. Some questions:
1.) Major issue is the crank - what crank to use. Do I just use any crank and use a single ring. Are there any really good cranks that you can recommend that I can order or CRC/CWC
2.) If i dont have horizontal dropouts do I need a tensioner? Can you get an after market eccentric BB that will fit a standard thread
3.) What thread does Trek run - I think being american it is English - I cant remember. Alwya had italian frames.
4.) Where do you get the pretty coloured chains etc ?
5.) Do you need front and back brakes ?
6.) What tyre width - 26mm or bigger ?
Any tips or tricks ?
Plan is to build this and learn from it and then see what else I like. If I like it I will build a single speed MTB but that will cost me.
Other ideas are a fatbike (anyone built one?) Not sure what i will do with it in JHB. Anyone got one?
Take a look at the links.
I have a 1988 Cannondale "Black Lightning" built as a SS,
I used these cranks and chain tensioner, both brilliant.
You can also use a "half link" chain and do away with a chain tensioner.
I would say Trek use an English BB Thread.
http://www.chainreactioncycles.com/Models.aspx?ModelID=17724
http://www.chainreactioncycles.com/Models.aspx?ModelID=75323
http://www.chainreactioncycles.com/Models.aspx?ModelID=31089
