Good day
The topic has most probably been discussed. Went the 29 er route with 2 x10 crank. Running a 38 currently on the big ring. Is this the norm and does this cater for most racing conditions?
More than happy with my 2x10 setup on my 29er easy to get used to from my previous bike (3x9 26er) Just spinning a little on my highest gear on a flat
,that problem can be solved by changing to a 39 teeth chain ring
Guest ctMTBer
I have 28/42 on my one bike and 26/39 on the other. 11-36 at the back. Hardly ever use te 42x11 and I don't run out off gears on the 39x11.
Go 26/39 and 11-36 cluster. It is all you wil ever need
