Sun Ringle Dirty Flea Rear Hub - Convert to Thru-Axle
Kallie.
Hi Hubbers,
I currently have Sun Ringle Dirty Flea hubs with QR fitted, does anyone know if it's possible to run the rear hub as thru-axle? If so, what needs to be done?
The reason for the question is that I am looking at buying a new frame but the rear wheel is thru-axle on the new frame and I don't really want to buy new wheels as well.
Thanks.
  • 7 months later...
Hi Hubbers,
Thanks.
Did you sort it out? Need to go from 12mm TA to QR. If you got the TA end caps can I buy your QR end caps?
  • 1 month later...
  • 2 years later...
  • 1 year later...
