Good Morning everybody
So I'm having a little trouble with my brakes... Completely disassembled them and cleaned etc then bled and I am having the same problem.
The cylinder that the lever pushes does not get pushed back by the spring when the lever is released, resulting a very long hard 30km (I was winning and didn't want to stop). The specs say to use DOT 3 or 4 and I have used dot 4. Without fluid in etc the levers work very well and the spring pushed back to where they should be, however with fluid in and connected to the pad they get stuck at the bottom.
Any suggestions?
Edited by RexFuzzle
Don't know these brakes (or breaks) but normally a brake return because the little rubber on the top of your reservour returns to its original shape and pull the fluid back . Start there .
I had the same problem with my Hayes Stroker Carbons a few years ago. After consulting with the guys at the LBS it turned out that this was a known problem with a batch of these brakes and that a rebuild kit was available to fix the problem. I don't recall exactly what the root cause of the problem was, but it was something along the line of the wrong grease being used during assembly at the factory or a defective O-Ring or something like that.
In the end though, it was going to take a week or 2 to get the rebuild kit and I wanted to ride that weekend, so I did a deal with the LBS and traded in the Hayes on another set second had brakes, so I don't know what the final outcome of the rebuild was.
A Google search for "hayes stroker sticking" will turn up numerous hits for this problem.
Thanks MooZN
Seems like some silicone spray is in order.
Oi, the pull generated by that little bellows is less than what a flea can pull - nothing.
The brake lever returns because of a spring attached to the master piston. The only thing I can think of that will prevent it is a swollen piston ring or a weak spring or very gritty lever pivots.
@ the OP. As for the mixing of the various fluids, Dot 3 and 4 shouldn't be mixed.
Here's a table of the various DOT fluids, the first column is obvious, the second one is the dry boiling point, the third one its composition and the fourth one, whether it can be mixed with other fluids OF THE SAME COMPOSITION. In other words, only mix Dot 4 and 5.1
Presentation1.pdf
Sorry, can't get the table in here as an image.
Type
Boiling Point
Primary Constituent
Edited by Johan Bornman
Type
Boiling Point
Primary Constituent
Mix?
Dot 2
190
Caster Oil/Alcohol
No
Dot 3
205
Glycol Ether
No
Dot 4
230
Glycol Ether/Borate Ester
Yes
Dot 5
260
Silicon
No
Dot 5.1
260
Yes
Mineral Oil
190
Oil - of fossil origin
No
EISH! that table didn't import to well, I'll JPG it and try again.
True but there are a few things in the assembly that makes the caliper return . Not one of them can do it alone , but I find that starting at the top working down normally works for me .
Thanks MooZN
No, don't do that. If your spray contains chlorine, it will make the rubber go gooey. You do get chlorine-free sprays but they are slightly more expensive and will specify on the can that they are Chlorine-free.
  • 1 month later...
So in the end it was a simple fix. There are two seals and the second one doesn't get lubricated much so I got some read grease and lubed it up and all seems hunky dory for now... Seems that the slow lever kit is no longer sold so this was the only solution.
