  • Replies 222
Thanks ml!  I have been looking over her in Holland at Cree and Luxeon.  Might try some new setups if I get time.  My rechargeable batteries are not too great anymore' date=' so I am looking for a better charger.  Lots to search for...[/quote']
I got some of these batteries plus chargers.
http://www.all-battery.com/index.asp?PageAction=VIEWPROD&ProdID=509
There are better batteries, but the shipping to SA usually kills it.
These guys were not too bad (if you take the risk of sending via the SA post office...)
All arrived.
Daai was nie ek wat hulle gevat het nie. Maar ek het almal gevat wat vanmiddag daar aangekom het!!! LOL
Bliksem! AngryAngry
Sal maar moet vra dat hulle weer bestel en vir my 'n paar hou!
Toemaar ml, al wat jy moet doen is om hom te blackmail met daai email printout wat onder die light housings le!  Interessante leesstofWink
camp gear,  heavy duty aluminium flashlight. There's no more information on the package, not even where it's made except that it can be focussed and stuff like that. Wonder if it's made in SA maybe?
ML will order some for you if you want. I'm going past there tom morning. They arrive 4 pm from the packhouse, they close at 5:30 so you can pick them up after work. how many do you want?
All arrived.
  Looks great, but isn't 2200mAh too high for the Luxeons?
Bliksem! AngryAngry
Toemaar ml' date=' al wat jy moet doen is om hom te blackmail met daai email printout wat onder die light housings le!  Interessante leesstofWink
I see it disappearedLOLLOLLOL
Willehond2008-09-22 14:24:52
Bliksem! AngryAngry
e-mail removed. Smile
Het nie besef dit le onder nie!!! is nie vir my of van my nie though...
All arrived.
Ai WH, moet ek jou nog die basics ook leer... (en daar gaan maak jy vir NT so skrik dat hy sy foto afhaal!)
2200 mAh is the capacity rating of the battery.
Actual current drawn will be determined by the impedance of the load.
Battery voltage is 14.8V. Most drivers (e.g. the BuckPuck) can handle that.
14.8V input voltage is just right to provide 3 LEDs in series with a constant regulated current from a buck type driver.
mountain_lion2008-09-22 14:33:02
All arrived.
14.8V input voltage is just right provide 3 LEDs in series with a constant regulated current from a buck type driver.
Embarrassed OK, OK, blonde moment!!!  Sjoe, nou voel ek stoopid
14,8V will actually be perfect for my Buckpuck!  Will have to order
Willehond2008-09-22 14:35:00
My newest housing for a few lights i'm going to build. looks very good!!!
Just have to do a little machining to customize the housing to work.
Pics are a little dark' date=' couldn't get the detail with the flash on.
Where can i get these housings, looks like the brighter lights ones.
  • 1 year later...
RE-USE and therefore I decided I'm going to use my cordless drill battery to power my 3x3W luxeon's. I hope I don't melt my front freeking tyre in the process :-)
