my trek has the duotrap sensor built into the frame, its paired with my garmin 500. i did a tyre rotation yesterday, then went for a ride......now whenever i go up hills (or any small incline ) i get either a 0kmh reading.....which gradually goes up to about 13-14 (i know im not going that slowly :whistling: ).......soon as i let up on the power or get to the top of the climb....it jumps back to the 20's...works perfectly when cruising along, only seems to do it when i put load on the wheel
now....obviously its not picking up the magnet some way or another....but checked wheel over....no problem. i cnt get the magnet any closer to the sensor, and since the sensor is built into the frame, that cnt move either. only other thing is wheel/spoke flex?
You dont need to use the speed sensor on the bike, your Garmin has a built in GPS and it is very accurate.
Delete the speed sensor pairing on your Garmin, happy days!
