2014 Stumpjumper Comp HT R23 799.00
The aluminum Stumpjumper HT Comp 29 features an 80mm-travel RockShox Reba fork with rebound and lockout adjustment and a custom SRAM 2x10 crankset.
M5 fully manipulated alloy HT frame with optimized 29er geometry features a PF30 BB, and PM 140 rear brake for a sleek, responsive and race-ready design
RockShox Reba RL 29 fork with 90mm travel, Solo Air spring and rebound adjust, and a 15mm thru-axle provides premium XC suspension performance w/Lockout and compression adjust
Roval 29 rims mated to Specialized Hi Lo hubs increase wheel stiffness for more confident riding
S-Works Fast Trak 29 2.0", 2Bliss Ready front tire features dual-compound rubber, delivering exceptional speed and traction while minimizing rotating weight
Custom SRAM S-1250 10-speed XC double crankset with 29er-specific gearing, large PF30 bearings, and alloy arms for smooth, efficient power transfer
Formula C1 hydraulic disc brakes provide consistent and reliable stopping power
2014 Crave Pro 29 R21 999.00
The all-new Crave Pro 29 is a competition-inspired aluminum hardtail 29er with a 100mm-travel Fox Evolution fork, Shimano Deore hydraulic disc brakes, and Shimano SLX shifters.
New, fully butted, smooth-welded M4 Premium Aluminum frame is super-lightweight, stiff, and features XC 29er Geometry, integrated headset, tapered headtube for front-end stiffness, plus bridge-less seatstays for compliance over bumps
100mm-travel FOX Float Evolution Series 29 fork with CTD damper, rebound adjust and tapered steerer tube is lightweight, plush, and tunable to help smooth technical terrain
Specialized Stout SL Disc 29" wheels feature double-wall rims with sealed bearings for lightweight, durable wheels
Custom SRAM 10-speed XC double-ring crankset with 29er gearing and GXP bottom bracket offers lightweight and durable performance paired with Shimano Deore XT Shadow Plus 10-speed rear derailleur for exceptional shifting performance
Shimano Deore hydraulic disc brakes use 180mm front rotor for increased braking power, while 160mm rear rotor keeps weight low. Shimano levers feature lever reach adjustment
OR a Scott in that price range or Bergamont ?
