Im looking to get myself a late xmas gift .I sold the old Momsen and im looking for a new one.
I had a look around and found 2 bikes i like.The Momsen AL629 and the X-AL
(yes I'm one of the big guys) .
Would probably replace the Crest on al 629 with Arch.
Any experiences good or bad, any advice or just your personal opinion on these two bikes.
MOMSEN AL629
Sizes X-Large Frame Race Tech 2, Alloy 6061 Butted Tubeset Fork FOX Float 29 CTD, 100mm Travel Chainwheel Shimano M615, 38/24 Bottom Bracket Shimano External F. Derailleur Shimano SLX R. Derailleur Shimano XT 10 Speed Shifter Shimano Deore Trigger Brake Levers Shimano M615 Hydraulic Brakes 180 Fr /160 Rr Cassette Shimano SLX, 11-36T Rims No Tubes ZTR CREST, 32H Tires Kenda Slant Six, Folding Bead, 29 x 2.0 Pedals Shimano M505 Clipless Handlebar Ritchey COMP 2x , 720mm, 31.8mm Oversize Stem Ritchey COMP 2x , 720mm, 31.8mm Oversize Seatpost Ritchey COMP 2 Bolt, 27.2 Seat Selle Royal Seta S1 Custom Headset Alloy Taper Integrated Colors Fast Black w/ Gold Details Chain KMC 10 Speed Hubset Shimano SLX Centerlock, 32h Spokes Stainless Butted with Alloy Nipples Grips Kraton Race Weight
11.65 kg ( Medium, Excl Pedals
Momsen X-AL
Sizes X-Large Frame Race Tech SLA -Alloy 7000 Butted Tubeset - Internal Routing -Formed Tubing - PressFit BB - 142 x 12 Thru-Axle Rear Fork RockShox SID RL 15mm Thru-Axle - 100mm Chainwheel SRAM X9 44/32/22T Bottom Bracket SRAM GXP PressFit F. Derailleur SRAM X9 R. Derailleur SRAM X9 Type 2 10 Speed Shifter SRAM X9 Ball Bearing Trigger Brake Levers Avid Elixir 7 Carbon Brakes 170 Fr /160 Rr Cassette SRAM PG1070 - 11-36T Rims Sun Ringle Inferno 27 - 32H Tires Schwalbe Racing Ralph SNAKESKIN Tubeless 29 x 2.25 Pedals Nil Handlebar Alloy Flat Top 29er - 680mm - 31.8mm Oversize Stem Alloy 3D Forged Superlight - 31.8mm Oversize Seatpost Alloy 3D Forged 31.6 Seat Fizik GOBI XM Headset FSA No 42 Alloy Taper Colors Matte Black w/Red Details Chain KMC 10 Speed Hubset SRAM X9 15mm Fr - SRAM X9 142 x 12 Rr - 32h Spokes Stainless Butted with Alloy Nipples
Grips
11.73kg ( X-Large, without pedals
I'd say both are strong points:
AL629
1) The SLX brakes on the AL629 is better.
2) Arch hoops better & stronger than Inferno's
X-AL
1) SID is a better fork I think.
2) BB and crank more standard and easier to replace / upgrade.
3) I don;t like the brakes.
I'd ask (if possible) for Arch wheels on the X-AL, and try to get either XT or SLX brakes on the X-AL. Then you have a killer bike!
My 2c.
  • 3 months later...
