Can anyone recommend me a floor pump for a mountain bike. Not too expensive. Maybe sub R300? If anything that half decent like that does exist in the wild?
All recommendation appreciated.
Spend a little more and the topeak joe blow mountain....really lekker pump...acurate dial and quick inflation
Where would I be able to find one in the CPT area?
I had a cheap Sportmanswarehouse pump.
problem was my wife could not use it for anything over 3 bar and the readings are to say the least very iffy.
rather spend a bit more and get a decent pump
check some online stores...cwc and evo
Otherwise most lbs's stock topeak stuffs....check your local lab too.
Serfas. Has a Brass barrel and a steel floor bracket. Pumps MTB tyres and road tyres. Comes with attachments to do soccer balls etc as well. Had mine a couple of years now. No hassles. Valve is Presta and Schrader compatible without having to strip it. Around that price point as well.
