I have been pondering the idea of getting a lefty and using it on an imported frame for a while, what put me off was that you would need to get a special adapter to use the lefty on a tapered head tube.
Then I saw that Cane Creek has a special headset for converting a straight head tube into a tapered one. It got me thinking, could the 1.5 bottom headset cup from this headset not be installed into the top of a tapered head tube, effectively making it 1.5 top and bottom, making it possible to use the standard lefty stem and steering pipe?
Just curios on what you guys think?
Thing is most of the Chinese frames comes with the headset "cup" moulded into the frame so I don't think your idea will work. Good idea though but not feasible on a Chinese carbon frame. Will work on something like a carbon Santa Cruz Highball/ Tallboy for instance.
Edited by BogusOne
You are correct, their headset cups are also very shallow, so not too much meat to press it into as well and I wont even risk trying to remove it.
But saying that, at least its another idea instead of using a R1500 steering tube adapter, so the idea is out there for someone to try. :thumbup:
With the price difference between a decent Cane Creek headset and a Project 321 adapter, you'll save yourself a whole lot of time and heartache just doing it the tried and tested way...
