Just had a ride of funny noises coming from the rear hub when free wheeling before a crack sound and loss of engagement between cassette and wheel on a climb. Have this one:http://pedaljam.co.uk/novatec-d712sb-rearhub.html
Is it a single closed unit and whole thing likely to need replacing? Or can pawls etc. be repaired/replaced and avoid a rebuild?
Just check,it could be that the retention bolta / cones / whatever mot have worked loose and caused the free hub to slide out of the notched or groved area inside the hub which the pawls interface with
You can rebuild the hubs, there should be a manual on their site that'll show you how it's done. No need to rebuild the wheel unless there's an issue with the hub shell.
