Prepsol can't cause the problem at all, so I think checking the tape and re-seating should do the trick. Only problem I've experienced with Prepsol is holding my Karcher too close and getting it into bearings...
never ever ever use a high pressure cleaner on a bicycle!!!!!!!! :eek:
you force dirt, cleaning products, grease, water etc into areas where you should never have any of these.
use a standard hose and take more time, you bike will last alot longer
