Gregstah Posted September 23, 2014 Posted September 23, 2014 Evening all :-) I wonder if anyone knows where I might get an adapter to convert a 15mm thru bolt to a 9mm Quick Release? Just got a 2nd hand wheel with at Specialized hub (not DT Swiss) which has a15mm thru adapter in it. I actually think the native size of the hub is 20mm see images. I have a Giant STP with Fox F80 shocks and have to use a 9mm Quick release which leaves me in a pickle :-P I'd really rather not replace the hub if I can help it. Thank you. Greg.
