Stans 3.3 hub endcap
Vangar
So crisis. One of the o rings on my Stans 3.30 hubs has split. Anyone have an idea of what size the o ring is or where in jhb i can get a replacement?
One of mine also damaged on the front wheel, should be able get one at bearing man. We have a bag with a lot of o rings in, used one of them not exactly the same size, but works fine.
I asked stans. It is 2mm*25mm and got today from Bearing Man. Stil a bit loose so I bought 24*2.5 as well to play with. Pity you are in Gauteng. I got loads spare now...
Ok. You made me get up in install them. The 24 * 2.5mm is to thick. It is 25*2mm. Still loose and need to be very carefull when pressing it in. I bought 10 spare. Very cheap. ..
