Pyga oneforty 650 Pascoe Build Project
warawowo
Xt brakes with weight. Per side.
Reverb switch visible on handlebar. I got the rightsided swith and flipped it over and mounted on the left side. Fits beautifully under the bar
  • Replies 76
Just a note, not too serious on an alloy bar but I see this all too often: you're missing the widget for your Reverb remote where it clamps onto your handlebar. There is a kidney shaped piece which fits in on the clamp and prevent over-stressing the bar. Remember these guys are designed to integrate with SRAM brakes so the widget is to be used when you are NOT running the remote in conjunction with SRAM brakes.
Ah thanx a million will see if I can find it and figure it out!
Wheels have arrived.
Never gonna be a superlight bike but opted for strength and durability.
Hope evo hubs
Sam xd driver.
No cassette on yet. No brake rotor on yet.
1kg rear
870g front
Hope evo hubs
Sam xd driver.
1kg rear
870g front
Sick build you putting together! What colour Hope hubs did you go for?
Initially planned on using mavic enduro wheels, the yellow ones to go with the yellow frame. After looking at some other pascoes online I decided that I liked the black wheels more. And I was disappointed that the enduros was so narrow.
I personally like the black rims better to.. The all yellow wheels and frame is to much, its as if the frame then dissappears from the focus.
