Wheel offset #2
Fisan
A week ago I complained about my wheel offset which at first seemed to be just a dishing problem. Now the dishing is perfected, but there is still an offset  :wacko: And to make matters worse, the wheel pulls even more to the side under compression.
Are my fork lowers in sy moer in?
FYI: It's a 2011 Rock Shox Reba 29 RL Air (QR). When I'm seated on the bike, the offset is about 2~4 mm. It increases with compression as stated above.
This happened with my Recon Gold's, bent lowers.. Apparently weak due to QR..
Supplier replaced lowers with Revelations lowers that have 15mm Axle and problem solved.
Bring it to me, I'll check it out for you. Could easily be bent lowers, although it's more common on SIDs than Rebas.
I've already booked my bike in at my LBS on Monday - but depending on their "diagnoses" I'll bring it to Stoke SW  :thumbup:
