1 x 10 conversion on a Cannondale Flash
JohanC
I'm posting this on behalf of a friend who needs some help with a conversion to 1 x 10:
Currently running Cannondale Hollowgram Cranks BB30 (120bcd)
Current setup - 2X10 Sram XO groupset.
Will this crank work with a 32 T blade or should he replace the crank
If the crank needs to be replaced, will a 1X11 Sram crank work?
If not which other crankset.
Chain to be replaced? Or any other parts needed?
As PeterF has said you will need to remove the Crank Spider in order to fit a direct spider mount 32T Chain Ring as the smallest you can go with a 120bcd is a 36T.
A SRAM BB30 Crankset will work as well.
