Faulty bike light
Dazshell
Anyone got any ideas on a quick-fix for my front light.  One of those LED ones with external rechargeable batteries.  It charges 100%, then when I plug the battery in sometimes it works and sometimes not.  I have checked and replaced the connecting plugs.  When it does work, it turns itself off after a few minutes.  It has 3 modes, bright, dim, strobe.  When it works, all 3 work fine.
Either a break in the wire as mentioned above, or a dry joint on the circuit. If you open it up be very careful not to touch any of the IC's as they are VERY sensitive to static and our fingers have enough to pop it.
