Frame respray
Pointer
Hi,
I need some advice. I have a Specialized s-works stumpjumper and noticed that there is spots on the frame where it seem like the clear coat is coming of.
Where can I have this repaired or resprayed if possible.
Attached is the frame that I have.
I am based in Pretoria.
Thanks.
Common problem on the spez, I know of 2ppl having the same problem on two different models one is a stumpy and the other a epic comp.
Try a warrantee claim first - then sebd to bogus - alternately there is a guy in jhb that does touch ups - will search for a number for you
Guest notmyname
+1 for cycle art.
