Power tap/garmin pairing
hayden_quade
Hello Hubbers,
Firstly, I Hope that the legs are spinning nicely.
Secondly, and down to business, I have a powertap 2.4, wireless, and a garmin 510. Both are ANT+. Does this mean that they are compatible? If yes, is there anyone who has the technical know how, and who can sort me out with some instruction on how to pair the two devices?
Thanks, ride well
Hayden
Yes, they're compatible.
On your Garmin screen, click the little spanner, go to bike settings, then bike profiles, select the profile of the bike you have the tap on, then click ant+ power. Make sure at the top where you can choose power meter yes/no, you select yes. Spin the wheel and press search on the screen.
Should pick it up.
If you read the Garmin manual or download it and read it you will find a comprehensive guide on how to set it up and "calibrate" it etc.
