XTR BL-M988 brake lever problem
KevinG
My XTR brake lever recently stopped working. When I pull the brake lever it doesn't return to its original position. Either the shaft is sticking on the seal or the spring is not working. Not sure. Anyway, Shimano says they cannot be repaired but I have heard there are guys who are able to repair these. Anybody had this problem solved? They are 2011 M988's.
