Silver for brazing
tommymac
Hey guys. Anyone know where I can get silver solider for brazing. I need to braze normal steel and stainless, and flux.
Trev
We  use silver solder on a daily basis - anything from about R2800 - R11000 per kilogram depending on the silver content - if the stainless is thinner than the steel you need to use a 40 - 55% rod due to the changes in the stainless from the additional heat required for the steel - doubt very much that you' find silver solder for R25 a stick - 0n 20 - 30% - closer to R80 - R150 per rod.
