XO Shifter with SLX Brakes
CraigCCW
I am wanting to replace my Formula R1 brakes with SLX, but the XO shifters attach directly to the Formula Levers (see enclosed pic).
I know there are Matchmaker components available, but there are a few options and I am not sure which ones to go for.
Are there any local suppliers of the Matchmaker components, or is there another way I can attach the XO shifter?
Run xo11 shifter with slx brakes and the setup is neat without matchmakers. also matchmakes limit you with the tilt on your shifter. witch can be a problem to climb 3 gears. a shifted to gripshift nou. still no porblem
Pricey, and I only need one.
Currently I can't run them separately, the XO Shifter cannot attach to the bars on its own, unless there is an adapter for that.
o so you need the standard clamp, i might have a spare one in my spares at home, however you not in Cape Town, speak to your LBS it costs like R150 or something, doesn't have to be new
Yes, I need the clamp.
I will speak to my LBS and see if they can source me one.
Thanks for the advice.
looks like this
