where can i get a smaller sunringle hub cap?
Mongooser
What model hub is it? I may know of a set for a Dirty Flea knocking around. If not I may be able to order from the agents.
can't find any model number or anything just says sunringle on the hub
Ok, going to need a photo then, and preferably a serial number which should be printed somewhere on a flange
May be a bit more complicated than just an end cap.  By changing the size of just one side will move the disc over and also affect the wheel dishing.  I would get a 2nd opinion before spending money.
found out that the frame takes a 135mm spaced hub,I have a 145mm
It's a kit - axle, bolts and spacers.
