Shimano XT replacement Brake Hoses
Ispeed_V
Check which hose your brakes use.  Depending on the age and model it could be BR H90 or BR H59.  If it is the 90 version you can get different lengths (front or back) with the connections fitted from a bike shop.  If it is the older 59 version you can buy the hose separately and reuse your fittings.  Otherwise a few after market options.
Thanks David
Hi Hubbers
Does any know where I can get replacement hydraulic brake hoses for Shimano XT Brakes.
My LBS stocks them. Ask your LBS to get you some if not in stock.
