Fox Evol damaged?
Scooterbike
What will happen if you ride about 80km of technical while rear shock is in closed position?
I noticed something weird and afterwards noticed that the lockout was stuck, not working. Will the shock be damaged?
No it will not be damaged as assume it was gravel roads mainly  , is the shock remote lock ?
you'd have to take A significant impact in lock mode to do any real damage to A rear shock
No dirt roads. Mainly single track with fast and rocky downhills but no major jumps.
take it to stoke suspension this week , they'll know whats up
but i wouldn't worry too much :)
I doubt you'd damage it, there are very few shocks that don't have some sort of blowoff for when you forget. A jammed lever still means you're in for a full rebuild 9 times out of 10 though...
