TT Aero Brake Caliper
Moooving
Howzit guys
I have a felt TT bike with the rear brake being aero (hidden away, not sure the correct name of it)
Does anybody know the correct rear brake calliper i will need for my bike.
I currently have the incorrect rear brake calliper.
Thanks in advance
Howzit guys
Thanks in advance
Is it a B series?
What's the issues with the 105?
Left crank arm touches part of the brake when cycling, then when i stop the touching problem the brake won't work because I've loosened the brake to stop the arm from touching if that makes any sense
That 105 brake won't work with the newer wider rims.
