Trek Top Fuel shock mounting hardware problem.
Blokeonabike
Hi everyone.
So I have a Trek Top Fuel frame. The frame is equiped with a Rockshox Monarch and does not use the current Trinion mounted shocks.
The mounting hardware I currently have is not the correct set. After properly installing the shock to the frame there is still about 1.3mm of play between the shock and the frame/spacers.
I have measured everything. The dimensions are 25 .4 x 8mm
I bought a set like this and is still doesn't work.
Does anyone know what the exact measurements of the spacers are? OR is anyone willing to remove their shock, measure the size of the spacers and let me know what they are?
If so I will be extremely grateful!
Wian Smith
