Fox floater loses air
Whitters
Just discovered my rear shock loses air. Assume it needs a service and new seals. Problem is I leave for berg&Bush on Thursday and the LBS says they need to send the shock to Cape town. They will try give it a clean and change the valve. Anyone know where I can get service seals in Ballito/Durban area? Hoping someone will carry them as I assume they must be a common serviced item.
Call Bike Works in Hillcrest and speak to Rowan and see if he can assist you. It’s a bit of a drive but well worth it.
A LBS that cannot do a rear shock seal service in under 1 hr shouldn't be called a LBS
