Wheel for Lefty compatiblity
samson99
When you say lefty 1.0 which do you refer to?
Generally lefty 2.0 uses a 60 mm wide hub flange and the earlier lefty a 50mm wide flange.
So 1.0 hub is compatible with 2.0 through the insertion of a spacer but the 2.0 hub isn't backwards compatible to 1.0.
But you need to be specific because cannondale made a mockery of lefty symplicity from 2012 onwards
Thanks DiD.
Your explanation totally explains the issue i was having. Tried to use the 2.0 front wheel on the lefty 1.0 and the hub was touching the fork. Now i know why.
Thank you.
