Hi, I'm attempting to build a 18 Scapel HI-Mod, I have a token BB asymetric but seems that the crank spindle is not long enough using that bb, does anyone know what bb I can get locally to make this work.
There is no BB that will make the XT cranks work in a 2018 Scalpel Ai frame.
the axle is 6mm to short and the bearing lands are in the wrong place.
You can use a Rotor Crank, or SRAM Ai or cannondale Hollowgram with the 137mm Hollowgram Ai axle.
PS: The SRAM Ai XX1, Ai XO1 or Ai Stylo are not std SRAM Cranks. These units have a custom axle but take the std SRAM 3 bolt mount XSYNC2 chainrings.
Your LBS will have to order these from Cape Cycle Systems.
Edited by DieselnDust
