Hi all and thank you in advance.
I inadvertantly bought a boost carbon fork and the hub floats left to right on the axle .
Are there spacers that one can buy to take up the float?
Regards
Regards
You get a kit with 2 x 5mm spacers and a brake rotor spacer (rotor also need to be offset by 5mm).  Hopefully you have 6 bolt rotors, for direct mount you screwed and the only option is to make up a bracket to space the brake caliper.
I will check if I can find the link again.
Edit:  https://www.bidorbuy.co.za/item/473745334/Fouriers_Boost_Hub_Adapter_Rear_Wheel_Hub.html?gclid=Cj0KCQjwnJaKBhDgARIsAHmvz6caGML1SQqInX_wimFv9JrqXeI-vY1k2LQh65VekAHye8_uc8iCvE8aApJxEALw_wcB
I don't find any local sites though.  Maybe someone else on here know where to get locally.  The other alternatives is to buy a boost hub and do a wheel rebuild or just to buy a boost wheel.
Edited by TheoG
