RABUBI Posted October 11, 2021 Posted October 11, 2021 (edited) I built a Gravel bike using my hardtail MTB. Groupset is 11speed Shimano. I then took an 11 speed Shimano Ultegra set of Shifters, but cant seem to get the gears dialed in. seems the indexing is totally different. anyone did this and had any luck? Edited October 11, 2021 by RABUBI
Knersboy Posted October 11, 2021 Posted October 11, 2021 What is important is that the rear derailleur and shifters match, the cassettes are compatible. Shimano uses a different pull ratio in their road and mtb drivetrains. 100Tours 1
peepeekaitjie Posted October 11, 2021 Posted October 11, 2021 https://www.wolftoothcomponents.com/collections/components/products/tanpan You probably need one of these. I have one using road shifters and mtb derailleur and gets them talking nice to eachother.
NickGM Posted October 11, 2021 Posted October 11, 2021 10 minutes ago, RABUBI said: I built a Gravel bike using my hardtail MTB. Groupset is 11speed Shimano. I then took an 11 speed Shimano Ultegra set of Shifters, but cant seem to get the gears dialed in. seems the indexing is totally different. anyone did this and had any luck? 10 and 11 speed shimano road shifters don't have the same pull ratios as MTBs. This was created for this very issue: https://www.wolftoothcomponents.com/products/tanpan Most older 9 speed shimano stuff is cross compatible though. very good explanation here: https://bike.bikegremlin.com/1278/bicycle-rear-derailleur-compatibility/
RABUBI Posted October 11, 2021 Author Posted October 11, 2021 16 minutes ago, Ari SW said: https://www.wolftoothcomponents.com/collections/components/products/tanpan You probably need one of these. I have one using road shifters and mtb derailleur and gets them talking nice to eachother. Thanks Ari. Where are these sold in SA?
peepeekaitjie Posted October 11, 2021 Posted October 11, 2021 My LBS built up a bike for me and put one on. Maybe try get your LBS to order you one through www.paragontech.co.za
MudLark Posted October 11, 2021 Posted October 11, 2021 (edited) On 10/11/2021 at 11:40 AM, NickGM said: 10 and 11 speed shimano road shifters don't have the same pull ratios as MTBs. This was created for this very issue: https://www.wolftoothcomponents.com/products/tanpan Most older 9 speed shimano stuff is cross compatible though. very good explanation here: https://bike.bikegremlin.com/1278/bicycle-rear-derailleur-compatibility/ Nick, we (myself and LBS) have mated 10 speed Tiagra hydraulic road shifters to XT derailleur and gear cluster on my Procaliber hybrid. Works perfectly. No tanpan required in that case. Edit: I haven't really used the bike much since the conversion was done. I took it for a spin yesterday. Looking down at the rear derailleur I saw it now reads 'Tiagra' My apologies. My bike shop was smarter than I was.... Edited October 17, 2021 by MudLark NickGM 1
NickGM Posted October 11, 2021 Posted October 11, 2021 4 minutes ago, MudLark said: Nick, we (myself and LBS) have mated 10 speed Tiagra hydraulic road shifters to XT derailleur and gear cluster on my Procaliber hybrid. Works perfectly. No tanpan required in that case. Oh, interesting. Tiagra 4700 is unique/different from all of the other shimano 10 speed stuff, and can actually be used with some of their 11 speed (Road) stuff and is aslo completely compatible with GRX range of 10 speed. As to mtb, I had no idea that would work.
Register a new accountSign in
