Hi All,
I've got a 2017 specialized AWOL frame and a 2x11 shimano mtb drivetrain that I'd like to fit to it. The front derailleur that is part of the unused group set is one of those direct mount types so I need one with a clamp mounting that is bottom pull compatible. To my knowledge, this is the one i need:
https://bike.shimano.com/en-EU/product/component/deorext-m8000/FD-M8025-H.html
Is there any reason why this wouldn't work?
(note: I'm aware that I'd need a shim/adaptor to compensate for the fact that the seat post tube is thinner than the clamp size).
I have that type of derailleur that you need - with a shifter/cable (removed it off my XT edition Merida)
I can confirm with you this evening to the exact part number and send you some pictures. DM me your number and I'll post you some pics later.
If its the one you need, you can have it for mahala. I'll throw in the 2 chain rings I removed off the XT crankset as well.
The parts are not new, but they were working perfectly when I changed to a 1x11
Edited by 117
Wow, thanks. Will DM you.
