5a4e47efaa03a__39149.1515113101.jpg.af7827352cf9c000c9a5c6bdf363268b.jpgGood day.  Is it possible to replace my 53/39 Dura Ace 10 sp  with 50/34 on the same spider, and who would be able to supply blades ?
Thank you.
Suspect you'll be hard-pushed to find compact chainrings for a 130 bcd crank.
Newer Shimano cranks are 110 bcd with 53/39 and 50/34 rings both fitting that standard.
Thank you.
Nope, u need 110BCD spider, old 5 arm shimano , I swopped mine out for Tiagra
I was able to swap my DA 53/39 for an Ultegra 50/34. I don't think there were many 10 speed DA compacts around.  If you buy a crank - new or second hand - get one that takes the new blades.  5 bolt chain rings are not that freely available and supply will only get worse.
Appreciate the advice. It does not have to be Dura Ace, all I want is any type of 50/34 blades that will fit Ultegra will be great if available?
Dura Ace 7800 only came in 130 bcd
thus a 50/34 will not fit.
I actually looking for a 7800 crank to complete one of my vintage builds...
and have a spare compact crank (110 bcd) but unfortunately it is not a Dura Ace 😔
Hi Mongoose. Can you give me more info on the crankset you have.  If I can't get blades for my crank looks like my only option will be to get a 50/34 complete crankset with the same type bottom bracket. Thx.
Thx mate. Looks like I'll have to replace the complete crankset to get a 50/34. Anyone out there have one available please let me know. Thx.
The alternative is to replace your cassette? Though there would be limitations in how large you can go - depending on your derailleur. However, even this can be overcome with a Wolftooth Roadlink: https://www.wolftoothcomponents.com/collections/drivetrain-1/products/roadlink
I originally had 52/39 cranks, but wanted 52/36, which was not possible without replacing my crank. So went 52/38 and put on a larger cassette at the back to give me the desired ratio.
Sheldon Brown can help with this calc: https://www.sheldonbrown.com/gear-calc.html
Edited by Smartie
Touch base with Mongoose. (see post above)
Perhaps you two can work out something.
I have a 53...39 if you are interested? DURA ACE
21 minutes ago, Dewald said:
Then I will have two. I need a 50/34 Thx.
only one if we swop ... (with cash difference depending on condition of yours and arm 🙃 )
