Hello folks
I have a Fox34 with remote lock out and i want to replace it with a manual lock out. The ID is C7S2
Is it possible to do this mod to the fork?
Im trying to unclutter the cockpit and have the manual lockout on my fox32, hence wanting to do it to the 34 as well
Merci,
If you want the indexing and all 3 settings you're in for a new compression assembly, but if you're ok with on/off you can just buy the adjusters.
Compression assembly will need to be done as part of a service cos the damper needs to be stripped to fit it.
