Morning,
While doing a brake blead over the weekend, my RHS shifter was spewing oil out of the tiny hole as per the arrow on the pic.
Hoping that some of the more technical folk can shed some light.
Sounds like a popped bladder. You may be able to get a replacement locally, but I'd need the model number to tell you which one - your LBS should be able to check for you though.
IF you can't get locally, SJS Cycles in the UK have most of Shimano's small parts.
Thanks. Thought as much.
Have mailed Evo Bikes. Hopefully they have.
