Interestingly' date=' IF is also 0.78, same as BikeMax, but I know I had something more left in the tank, whereas he was dying.
I should also add that I'm 62kg.
I should also add that I was in the same team as BikeMax, so our numbers make an interesting comparison.
  • Replies 50
So, niterider, you rode at 3.45 watts/kg - not bad!  Only problem with you little guys is that you don't help us big guys much in the wind Ouch and then you ride away from us up the hills!!
So' date=' niterider, you rode at 3.45 watts/kg - not bad!  Only problem with you little guys is that you don't help us big guys much in the wind Ouch and then you ride away from us up the hills!![/quote']
That's if we can hang on in the wind... Dead
