Came across this on Bike Radar
http://www.bikeradar.com/fitness/article/training-running-on-empty-18071
"If you think glycogen is the stored form of carbohydrate we
use to produce the energy required for cycling, you would be correct. However,
glycogen does a lot more than just that. Scientists have discovered a
crucial second function that directly affects endurance performance and could revolutionize the way we endurance train."
?There are essentially three things that limit endurance
performance: VO2 max, lactate threshold and cycling economy,? says Dr Keith
Baar of Dundee University, an expert on AMPK.
?Improved glycogen signaling can boost two out of the three: VO2
max and lactate threshold.?
Makes for interesting reading.........
PPWTF2008-09-29 12:27:32
?Improved glycogen signalling can boost two out of the three: VO2 max and lactate threshold.?
This
would be interesting but not practically useful were it not for one
crucial point, the scientists showed our signalling function can be
improved by training when glycogen stores are low, which is a radical
break from conventional wisdom.
How low-level glycogen training affects performance
Generally,
athletes of all levels are told to have a carbohydrate-rich meal two to
three hours before any training occurs, ensuring their glycogen levels
are fully topped up.
But these studies suggest that purposefully
manipulating your glycogen level so that it?s around one third depleted
results in improved signalling, hence greater muscular mitochondrial
mass and better endurance performance.
?The exact mechanism is still being investigated, but this could work in a number of ways,? says Baar.
?For
example, training on low glycogen puts the body under extra stress,
meaning it produces more adrenaline. Therefore the body adapts to
dampen the body?s response to adrenaline, which in turn helps to
increase the lactate threshold?.
How to train your signal pathways
Dr
Baar?s fellow boffins at the University of Birmingham have even created
a training session specifically designed to increase the signalling
function of glycogen. The idea is to purposefully lower your glycogen
until it?s depleted to the right level, then to do some high-intensity
training in that state.
Have a low-carbohydrate meal prior to
the session and then beginning the workout with 45-60 minutes of
low-intensity, steady cycling at around 70% of your VO2 max (a level
where you can still breathe through your nose, with your mouth shut).
After your glycogen is sufficiently depleted, switch to intervals of five minutes? hard exercise with a minute of rest in between.
This will train your signalling pathways to maximum effect.
?We
know from studies that training at high intensity activates AMPK at a
greater rate, plus we know this effect is improved when training at
lower glycogen levels, so this session gives twice the activation,?
Baar explains.
Short-term limitations versus long-term benefits
Before
embarking on glycogen manipulation training, it?s important to
recognise its limitations. For example, if you?re a track rider and
don?t race for longer than an hour, this type of training is going to
be largely ineffective on your short-term performance.
The
reason for this is that improving your glycogen signalling increases
your energy efficiency at slower speeds, when you are undergoing aerobic
respiration and want as much fat-burning as possible. Racing shorter
distances for an hour or less requires a faster speed, meaning that
your body has to burn carbohydrate no matter what, so glycogen
signalling is largely irrelevant.
But for longer distance
events, particularly stage rides where you have to pedal day after day,
this type of training can bring definite benefits.
Only pure endurance will get the full benefit
You
also need to be careful about when and how often you perform this kind
of training. Unlike running, which requires only pure endurance,
cycling also requires a degree of explosive muscle strength to power
the pedals.
Crucially, glycogen manipulation will only work for
pure endurance training. So there?s no point going into a weights
session in a glycogen-depleted state because you?ll simply fail to get
the full benefit from the workout.
At this stage it's probably only applicable to real elite level performance - the reason it caught my eye is;
  1. That science is routinely bashing many of the old 'accepted' wisdoms of endurance training over the head
  2. No sooner is quality academic research complete than this info is available in the public domain
Factor 1 & 2 together and never has there been a better time to be an up and coming athlete
PPWTF2008-09-30 03:26:03
?For
example' date=' training on low glycogen puts the body under extra stress,
The problem is under heavy load (intervals) on low glycogen levels your body tends to cannibalize muscle tissue for energy which is both counter-productive and increases recovery time.
