On my Ultegra cranks it has a big black bolt which you use to get the left crank arm in place. I went to my LBS and I got a silver DA one but guess what, it does not fit. The DA one is much bigger. Luckily the LBS had it wrong on their system and I got it for only R15. So if someone knows if there is a way to replace the black one with a silver one it woul dbe appreciated and if someone needs a DA one, you can pm me and you can have it for mahala.
