Carbos Explained...or at least info to help
The
Science:
Yes, there is not much
difference between sucrose, glucose and dextrose. All soluble dietary
Carbohydrates are eventually metabolized (broken down) into Glucose.
Due to the uniqueness
of the human physiology and the complexity of the body?s metabolism some
compounds could not be defined by text book theories, and the individual
understanding of how single and combined nutrients act within the body during
specific conditions are hard to determine. The collection of long standing
studies and a vast amount of test data collected from different study conditions
and nutrient applications contributed to the specific ratio of macro- and
micronutrients contained in the Whasp gel formulation. The question is; which
carbohydrates could on its own increase blood glucose for energy without
actually increasing the blood sugar (glucose).
The
answer is in the ratio between the different carbohydrates with the addition of
specifically selected Amino Acids and the addition of protein and fatty acids
such as Medium Chain Triglycerides.
Whasp
Gel Carbohydrate breakdown:
Whasp gel does not
contain any added sucrose,
Maltodextrin:   35% - 45%       of
total carbohydrates.
Glucose
syrup:
50% - 55%       of
Honey:             8% - 10%
         of total carbohydrates.
o
Fructose is 38% - 42%
of the 2.5g of honey = < 1g of total Whasp gel. < 3.6% of total
carbohydrates
o
Sucrose +/- 2 % of the
2.5g of honey = < 0.05g of total in Whap gel
Glycerol:          7% - 9%
Glucose:
Glucose is the only
Carbohydrate that actually circulates within the bloodstream (i.e. as Blood
Sugar) and is much needed for energy especially during extreme physical
endurance. Glucose provides Energy (via Adenosine Triphosphate [ATP]) to most of
the body's Cells and is the preferred fuel for most Cells (including the Neurons
of the Brain).
Substances
that enhance the function of Glucose:
Supplemental
Medium-Chain Triglycerides (MCTs) may be more effective for improving Athletic
Performance and Stamina when they are consumed simultaneously with
Glucose.
-           Some human
studies indicate that MCTs are ineffective for Athletic Performance and Stamina
improvement unless they are consumed concurrently with
Glucose.
Substances
that inhibits the rapid absorption of Glucose:
Amino
Acids
Medium Chain
Triglycerides.
Green Tea
Extract
Substances
enhanced by Glucose:
Glycerol is formed when
the Glucose molecule is split in half, forming two Glycerol molecules from
excessive dietary Glucose derived from metabolized dietary Carbohydrates - the
Glycerol so formed is then utilized in the endogenous manufacture of
Triglycerides.
Why
use Glycerol?
Endurance Athletes
sometimes ingest large quantities of Glycerol (in order to induce Water
retention) immediately prior to Endurance Exercise - the usual dosage of
Glycerol used by endurance athletes is 1 gram of Glycerol per kilogram of body
weight.
Glycerol attracts Water
and readily permeates Cell Membranes by causing a change in pressure across Cell
Membranes.  It therefore counteracts the accelerated loss of Water (Dehydration)
sustained by endurance athletes (especially when endurance Exercise is conducted
in warm - hot temperatures).
The Glycerol component
of Triglycerides (stored within the body as Adipose Tissue and released when the
body requires Energy) can be converted to Glucose (similarly to the conversion
of Glycogen to Glucose).
Substances
which neutralizes free radicals, inadvertently formed during strenuous
exercise:
Green Tea Leaf
Extract
Vitamin
E
Vitamin
C
This is a brief
overview regarding the careful selection of the carbohydrates used in the
formulation of the gel and the ratios between the different carbohydrates and
the addition of MCT and amino Acds.
Looking at the table
most of the opposition are using Maltodextrin as their main carbohydrate.
Interesting that
Maltodextrin has a GI of 150 and Glucose 100. This means that the spike from
Maltodextrin, as your main carbohydrate, will be 50% higher than with
Glucose.
The Science:
Yes' date=' there is not much difference between sucrose, glucose and dextrose. All soluble dietary Carbohydrates are eventually metabolized (broken down) into Glucose.
Due to the uniqueness of the human physiology and the complexity of the body?s metabolism some compounds could not be defined by text book theories, and the individual understanding of how single and combined nutrients act within the body during specific conditions are hard to determine. The collection of long standing studies and a vast amount of test data collected from different study conditions and nutrient applications contributed to the specific ratio of macro- and micronutrients contained in the Whasp gel formulation. The question is; which carbohydrates could on its own increase blood glucose for energy without actually increasing the blood sugar (glucose).
The answer is in the ratio between the different carbohydrates with the addition of specifically selected Amino Acids and the addition of protein and fatty acids such as Medium Chain Triglycerides.
Whasp Gel Carbohydrate breakdown:
Whasp gel does not contain any added sucrose,
-          Maltodextrin:   35% - 45%       of total carbohydrates.
-          Glucose syrup: 50% - 55%       of total carbohydrates.
-          Honey:             8% - 10%          of total carbohydrates.
o        Fructose is 38% - 42% of the 2.5g of honey = < 1g of total Whasp gel. < 3.6% of total carbohydrates
o        Sucrose +/- 2 % of the 2.5g of honey = < 0.05g of total in Whap gel
-          Glycerol:          7% - 9%            of total carbohydrates
Glucose:
Glucose is the only Carbohydrate that actually circulates within the bloodstream (i.e. as Blood Sugar) and is much needed for energy especially during extreme physical endurance. Glucose provides Energy (via Adenosine Triphosphate [ATP']) to most of the body's Cells and is the preferred fuel for most Cells (including the Neurons of the Brain).
Substances that enhance the function of Glucose:
Supplemental Medium-Chain Triglycerides (MCTs) may be more effective for improving Athletic Performance and Stamina when they are consumed simultaneously with Glucose.
-           Some human studies indicate that MCTs are ineffective for Athletic Performance and Stamina improvement unless they are consumed concurrently with Glucose.
Substances that inhibits the rapid absorption of Glucose:
-          Amino Acids
-          Medium Chain Triglycerides.
-          Green Tea Extract
Substances enhanced by Glucose:
Glycerol is formed when the Glucose molecule is split in half, forming two Glycerol molecules from excessive dietary Glucose derived from metabolized dietary Carbohydrates - the Glycerol so formed is then utilized in the endogenous manufacture of Triglycerides.
Why use Glycerol?
Endurance Athletes sometimes ingest large quantities of Glycerol (in order to induce Water retention) immediately prior to Endurance Exercise - the usual dosage of Glycerol used by endurance athletes is 1 gram of Glycerol per kilogram of body weight.
-          Glycerol attracts Water and readily permeates Cell Membranes by causing a change in pressure across Cell Membranes.  It therefore counteracts the accelerated loss of Water (Dehydration) sustained by endurance athletes (especially when endurance Exercise is conducted in warm - hot temperatures).
-          The Glycerol component of Triglycerides (stored within the body as Adipose Tissue and released when the body requires Energy) can be converted to Glucose (similarly to the conversion of Glycogen to Glucose).
Substances which neutralizes free radicals, inadvertently formed during strenuous exercise:
-          Green Tea Leaf Extract
-          Vitamin E
-          Vitamin C
This is a brief overview regarding the careful selection of the carbohydrates used in the formulation of the gel and the ratios between the different carbohydrates and the addition of MCT and amino Acds.
Glaecemic Index (GI) has to do with the difference between between sucrose, glucose and dextrose. With glucose having the highest GI and thusbeing taken up into the blood the fastest.
To increase blood glucose for energy, you have to increase blood glucose levels.
I think what you mean is what ratio and amount of carbohydrates (CHO) would sustain blood glucose levels without causing an insulin response.
An insulin response happens when the blood glucose levels are elevated to such an extent that the pancreas secretes excess insulin to "normalise" blood glucose. Blood glucose then briefly falls below baseline (normal) levels which causes you to "hit the wall" or "bonk".
Sucrose is also not all bad as it is a disaccharide and has a GI lower than glucose...
What you said about MCT's are quite correct! They are the only of "fats" that get absorbed straight from the gut into the blood. Thus having a sparing effect on blood glucose.
Resaerch on glycerol has been inconclusive, though certain performance enhancing effects have been observed.
